patsch
Apr 18, 2019Tutor
New Nighthawk App - where are the parental controls??
As suggested by Netgear I had set up an OpenDNS account and used the Netgear Genie App to enable / disable the parental controls on demand.
Today I was forced to upgrade to the new Nighthawk Ap...
lauranda
Jun 29, 2019Tutor
If you are still under warranty or have insurance with SQUARETRADE you can file a claim.
- gojambiAug 07, 2019Aspirant
How do I file claim? I bought Dec 2018 for the sole purpose of having parental control feature. Looks like Genie desktop app is gone, nothing in the admin of the router and as of April 10 the Disney Circle app is gone. I want my money back to buy a router which does have this feature. Help!
- DexterJBAug 07, 2019NETGEAR Moderator
Hi gojambi, welcome to the community! The desktop Genie will continue to work for the Live Parental Controls feature. You can download it on the link below and go to the DOWNLOAD PC or DOWNLOAD MAC links at the bottom.
https://www.netgear.com/home/discover/apps/genie.aspx
Also, your router (R6900) is among the models that do support the Disney Circle feature as described on the link below.
https://kb.netgear.com/000044718/What-NETGEAR-routers-support-Circle-with-Disney
Dexter
- schumakuAug 08, 2019Guru - Experienced User
DexterJB wrote:Hi gojambi, welcome to the community! The desktop Genie will continue to work for the Live Parental Controls feature.
Sorry Dexter,
Lot of features previously available with the Genie Apps only are not available on the desktop Genie. And the bypass account can't be used on the mobiles now, too. This aint a solution...
