patsch
Apr 18, 2019Tutor
New Nighthawk App - where are the parental controls??
As suggested by Netgear I had set up an OpenDNS account and used the Netgear Genie App to enable / disable the parental controls on demand.
Today I was forced to upgrade to the new Nighthawk Ap...
lauranda
Jun 29, 2019Tutor
If you are still under warranty or have insurance with SQUARETRADE you can file a claim.
gojambi
Aug 07, 2019Aspirant
How do I file claim? I bought Dec 2018 for the sole purpose of having parental control feature. Looks like Genie desktop app is gone, nothing in the admin of the router and as of April 10 the Disney Circle app is gone. I want my money back to buy a router which does have this feature. Help!
- DexterJBAug 07, 2019NETGEAR Moderator
Hi gojambi, welcome to the community! The desktop Genie will continue to work for the Live Parental Controls feature. You can download it on the link below and go to the DOWNLOAD PC or DOWNLOAD MAC links at the bottom.
https://www.netgear.com/home/discover/apps/genie.aspx
Also, your router (R6900) is among the models that do support the Disney Circle feature as described on the link below.
https://kb.netgear.com/000044718/What-NETGEAR-routers-support-Circle-with-Disney
Dexter
- schumakuAug 08, 2019Guru - Experienced User
DexterJB wrote:Hi gojambi, welcome to the community! The desktop Genie will continue to work for the Live Parental Controls feature.
Sorry Dexter,
Lot of features previously available with the Genie Apps only are not available on the desktop Genie. And the bypass account can't be used on the mobiles now, too. This aint a solution...- gojambiAug 08, 2019AspirantI downloaded circle Disney app and it says to connect to my WiFi which I am and the app doesn’t think I’m connected. Does this app even work? If so how do I setup and can I set specific times to shut down WiFi?? That’s why I bought the router
- earthsoundAug 08, 2019Star
DexterJB wrote:Hi gojambi, welcome to the community! The desktop Genie will continue to work for the Live Parental Controls feature. You can download it on the link below and go to the DOWNLOAD PC or DOWNLOAD MAC links at the bottom.
Dexter
Dexter,
Since the R6400v1 isn't supported, could you have the engineers set the Genie iOS and Android apps to allow it to keep managing those routers instead of pushing us to an app that doesn't even support our hardware or our Live Parental Controls?
Thanks!
This link brings up a new page with the new Netgear app. Don't see anything in there for parental controls. I upgraded firmware in router to latest. No parental controls from admin page. When I use circle w/ disney app it says connect to your wifi network. I am and I get an error "couldn't find circle on your router" Do I need another piece of hardware to use in addition to the router? Do I need to buy a circle device? I"m about ready to sell the router and buy one with real parental controls. ANy help?
