Dustin_V
Jun 22, 2018NETGEAR Employee Retired
New Nighthawk App 2.2 Now Available!
The Nighthawk App is now available to upgrade. Download the latest version to enjoy performance improvements, bug fixes, and the latest features like Remote Management. Now you can eas...
80njc80
Jun 25, 2018Luminary
D7800 is not supported error? Looks like the following have been added in the version histories:
- Support for R6400v2 and R6700v3
- Supports the R6020, R6080, R6120, R6220, R6230, R6400, R6800 and R6900v2
- Added support for Nighthawk XR500
michaelkenward
Jun 25, 2018Guru - Experienced User
Looks like no modem routers are on that list. Were they ever?
The Android app says it is for routers.
- 80njc80Jun 25, 2018LuminaryYup. But Netgear still email product updates as per below with direct links. It’s the little things that need to change...
“Don't Forget! We've Enhanced Your D7800 Product Security.
If you haven't already updated your router's firmware, you can do so using the Nighthawk App”.- michaelkenwardJun 25, 2018Guru - Experienced User
Joined up thinking, that would be a good idea.
