Dustin_V
Jun 22, 2018NETGEAR Employee Retired
New Nighthawk App 2.2 Now Available!
The Nighthawk App is now available to upgrade. Download the latest version to enjoy performance improvements, bug fixes, and the latest features like Remote Management. Now you can eas...
michaelkenward
Jun 25, 2018Guru - Experienced User
80njc80 wrote:
D7800 is not supported error?
Looks like no modem routers are on that list. Were they ever?
The Android app says it is for routers.
80njc80
Jun 25, 2018Luminary
Yup. But Netgear still email product updates as per below with direct links. It’s the little things that need to change...
“Don't Forget! We've Enhanced Your D7800 Product Security.
If you haven't already updated your router's firmware, you can do so using the Nighthawk App”.
