Dustin_V
Jun 22, 2018NETGEAR Employee Retired
New Nighthawk App 2.2 Now Available!
The Nighthawk App is now available to upgrade. Download the latest version to enjoy performance improvements, bug fixes, and the latest features like Remote Management. Now you can eas...
Rbenard
Jul 12, 2018Aspirant
Genie properly suspends internet. Nighthawk app suspends but then wipes name of device and type of device (changes name to _ _).
Edit: when updating name / type Nighthawk app will not consistently save name/type. There seems to be no pull down on device list page refresh function.
schumaku
Jul 13, 2018Guru - Experienced User
Luckily I don't think Genie has this power yet 8-)
Talking of "Device List" and the ability to Pause/Resume the Internet access? Must be a specific problem with your router firmware and or configuration. Works nicely using the Nightawk App (2.2.0.368 on Android 8.1) e.g. against the R9000 v1.0.4.3 here.
The update/refresh does happen automatically - at least when a device is connected resp. disconnected from the (W)LAN - within about 10 seconds. Concurrent administration using different Apps/WebUI might not be a good idea as there is no lock (beyond of the Web based Genie sessions) and data push in place, the routers are pure single-user administration devices.
