Todd707
Jan 29, 2024Tutor
New Phone, can't log in, Device not recognized
Nighthawk App not allowing me to log in from new Samsung S24 phone. Quickly says Device Not Recognized, then flips screen to Login Denied. I can log in via web admin. Have always had mobile phon...
michaelkenward
Feb 04, 2024Guru - Experienced User
At what stage does it fail?
- Todd707Feb 04, 2024Tutor
As soon as you try to sign in to existing account (that used to work fine on my older Samsung Galaxy 20), after entering password, it goes to 2 quick screens: We don't recognize this device, then flips quickly to Login Denied.
I've tried changing the MAC randomizer to Phone, and that didn't change anything.
Todd
- michaelkenwardFeb 04, 2024Guru - Experienced User
I asked because this is a multi-step process.
So the app happily connects to the wifi? That's the first step.
The next password it wants is for Anywhere Access followed by the router itself.
The Anywhere Access bit is the front end for all of the devices you want to get at. (I have a couple of routers, each with their own password.)
You have to set this stuff up with a wifi connection to the router before you can go out an use Anywhere Access with a remote connection.
So there are various places where things can go wrong.
I'd be wary of doing things like that.
- Todd707Feb 05, 2024Tutor
I'm not sure what to do with your suggestion. Any specific steps I need to do on my phone?
