Todd707
Jan 29, 2024Tutor
New Phone, can't log in, Device not recognized
Nighthawk App not allowing me to log in from new Samsung S24 phone. Quickly says Device Not Recognized, then flips screen to Login Denied. I can log in via web admin. Have always had mobile phon...
Todd707
Feb 05, 2024Tutor
I'm not sure what to do with your suggestion. Any specific steps I need to do on my phone?
BrianPat412
Feb 07, 2024Initiate
Was this resolved? I have the exact same issue!
- Todd707Feb 08, 2024Tutor
It has not been resolved unfortunately. I was able to send in a bug report from the phone. Once the error comes up, you shake the phone back and forth several times for a bug form to come up to submit.
- BrianPat412Feb 11, 2024Initiate
I got around the problem
I had a second backup email address and when I started the app, instead of using an existing account, I created a new one using the backup email address. All set now. I didn't enable 2FA, as I think that's the cause of the problem, the fact it can't hit your old phone after you've replace it!
