LuckyLief
Jan 13, 2017Aspirant
new R7800 wired Genie connection doesn't work
I got this new yesterday . It has firmware 1.0.2.04 and the genie version is 2.4.36. I can connect wirelessly and use the managment software but it does not connect through ethernet. I can get the Internet with wired but when I go to do any management function it will not logon and tells me I am not connected with WI-FI. <p> I am connected to Time Warner (now Spectrum) via an ARRIS router. I can logon the ARRIS and there is no IPv6 enabled. I want to update to the newest firmware for the 7800 but am concerned to do it with WI-FI when they recommend doing a wired connection for that. <p> Reading about the wired problems really makes me nervous because I have a boatload of wireless devices but also several that depend on wired connections including TV's, blu-ray, Fire devices and computers.<p> Helpful suggesytions gratefully received.
Sort By
- DexterJBNETGEAR Moderator
Hi LuckyLief,
1. You can update the router's firmware by accessing the UI via a browser. You can check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/23960
Note: Please make sure to perform a factory reset after updating the router's firmware. Check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/9665
2. If you are still unable to login via the NETGEAR Genie app/program, you can try uninstalling and re-installing it.
3. Try logging in using another device (Android, iOS, another computer).
Dexter
Community Team
- LuckyLiefAspirant
Hi Dexter, Thanks for your reply. I slept on it and then uninstalled Kaspersky amd was able to connect through ethernet directly to the router today. Kaspersky seems to be a bottleneck that cannot be got around. I updated the firmware to 1.0.2.20 and it seemed to be fine after rebooting. I did not do a factory reset. So far it seems to be working fine. fingers crossed.I am connecting to Fire TV with 5G and most other things with the 2.4. I am expecting to like it.
