mikalias
Jan 06, 2017Aspirant
new router say's inter 'Not Connect' in red but everything works
When I tried to setup my router I tried to use the net genie but it alway fails at one point so I set it up manual and it worked but now when I log in under the home column and the Internet tab it sa...
DexterJB
Jan 10, 2017NETGEAR Moderator
Hi mikalias,
1. Are you referring to the Internet Status when viewing the router UI via a browser?
2. Does it show an IP address on the Internet port box under Advanced > Home?
3. Please make sure that your devices are connected to the correct network (both wired and wireless).
Dexter
Community Team
mikalias
Jan 13, 2017Aspirant
No, I'm talking about the router when you log in as admin. The home tab at the top and it show a little world icon and below it, it says 'NOT CONNECTED' but I am connected because all the other tabs are green and my internet work fine and yes it shows an IP port address under advanced. The seperate app that runs outside the router 'Netgear Genie' show's the same little icon of the wold but it is green and says internet is connected but the router does'nt. All my wifi works fine too. really odd.
Mike
- Marcus305Jan 15, 2017Aspirant
I am having the exact same issue as Mike.
Dexter - yes, I think we are both talking about the router user interface (UI) that we access through our browsers (by going to www.routerlogin.net). The Genie app shows a good internet connection but the browser UI says "Not Connected" for the Internet status. I was also not able to use the wizard to initially set up my router because the Genie web UI found there to be no internet connection. Nevertheless, I was able to access the internet on my wired and wireless devices, so the router seems to be functioning okay.
I believe there is a problem with the UI that is accessed through a browser that is causing this false error (as well as preventing the use of the wizard to set up the router).
- DexterJBJan 15, 2017NETGEAR Moderator
That is indeed strange. What is the model number and firmware version of your respective devices?
Here are some steps that you can try.
1. Reset the router back to factory defaults.
2. Make sure that the firmware is up to date.
3. If firmware is up to date, try re-flashing the latest version then perform a factory reset.
Dexter
Community Team
- Marcus305Jan 16, 2017Aspirant
Mine is the R6700, and I am on v1.0.1.14_10.0.29 (which is the latest version that was released in late December 2016). I have tried the factory defaults and even tried flashing it back to the previous firmware version. Neither worked so I reflashed it back to the latest version, I am convinced that the problem is related to the Genie web interface (not my router) and how the interface is attempting to determine whether there is a good internet connection. The lights on my router are correct, I'm having no issues accessing the internet on my devices, and the Internet status on my Genie Windows App says "good."
This is indeed strange, but it appears that this problem has been experienced by others in the past. For example, please see the following threads (the first indicated that Netgear might have been experiencing a server problem):
Thanks for your assistance.
