AH-1
Dec 11, 2024Aspirant
Nighhawk AC4000 Tri-band (R8000P) - Nighthawk app conflicts with Mobile app
At home, I use a Nighthawk AC4000 tri-band router connected to a (non-Netgear) Technicolour modem. I use the "Nighthawk" app on my smartphone. No problems, all ok. Recently at the local village ...
- Dec 19, 2024
Thanks for the input.
The consensus is that the MR1100 M1 router does not have Anywhere Access capability.
Dec 11, 2024Guru - Experienced User
NH app only works with Nighthawk R, RAX, RAXE and RS series routers.
the Netgear MOBILE app only works with the MR series of cell service mobile routers.
