AH-1's avatar
AH-1
Nighhawk AC4000 Tri-band (R8000P) - Nighthawk app conflicts with Mobile app
At home, I use a Nighthawk AC4000 tri-band router connected to a (non-Netgear) Technicolour modem.  I use the "Nighthawk" app on my smartphone. No problems, all ok.   Recently at the local village ...
  • AH-1's avatar
    AH-1
    Dec 19, 2024
    Thanks for the input.
    The consensus is that the MR1100 M1 router does not have Anywhere Access capability.
