vyth
Jan 15, 2021Follower
NightHaw app has no "Anywhere Access" in settings for C7000v2
My AC1900 Wifi Cable Modem Router Model: C7000v2 firmware version: v1.03.01 app version: 2.7.61379 I'm unable to configure Anywhere Access, or remote access, on the app since there is no such ...
michaelkenward
Jan 15, 2021Guru - Experienced User
Did you check the bit in the manual on Remote Management?
You'll have to set that up before you can use it on the apps.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Cable Modems & Routers
schumaku
By far not every Netgear router does support Anywhere Access. Look on How do I enable or disable Anywhere Access on my router using the Nighthawk app? for the models listed under "This article applies to:". Features not available on the router accessed by the Nightawk App will be invisible.
michaelkenward wrote:Did you check the bit in the manual on Remote Management?
Nope! Completely unrelated. Anywhere Access does not expose the router WAN/Internet interface to the wild Internet. Much more it's a cloud solution. Remote Management MUST NOT be enabled for Anywhere Access.
