Citydweller11
Jun 22, 2022Aspirant
Nighthawk 6900 device manager not showing connected devoces
Hello for the last six months my Netgear nighthawk are R6900 device manager has not been showing all connected devices. This used to work really well where you could see everyone connected to your Int...
Jun 23, 2022Guru - Experienced User
do they show up in the access control page?
I've seen a lot of issues with the attached devices page. Sometimes a reset fixes it, sometimes you need to downgrade if it bothers you
- Citydweller11Jun 23, 2022AspirantThey do show up on access control page for the most part. What do you mean by downgrade?
- plemansJun 23, 2022Guru - Experienced User
You can try downgrading the firmware a version or 2. I've seen updates to firmware cause issues with the attached devices list. Or you can just use the access control list.
