Mike_Demler
Mar 02, 2016Aspirant
Nighthawk AC1900, Model R7000 DHCP server is faulty. Problems with Windows 10 & non-PC devices
Here is a list of issues I have expereienced with the R7000. Netgear refuses to give me a refund, and their online tech support folks just keep suggesting changes in the firmware, first to regress to...
Mike_Demler
Hi Searay
As I noted in my post, I've already done that. It only made matters wore. All the problems I listed above are occurring with the V1.0.4.30_1.1.67 firmware. The lack of SSID identification is one example of a problem that I did not see with the V1.0.6 firmware. I also did not see this new issue of Ethernet ports working while Wi-Fi connections were blocked, though the drastic slowing of Wi-Fi connections occurred in both cases.
Thanks.
Retired_Member
Mar 02, 2016I understand you've already done it. I also feel your pain when it comes to nitgear.
It might be worth doing it again.
Good Luck!
- Mike_DemlerMar 02, 2016Aspirant
Installing beta code is their last resort, but I'm swearing off Netgear and will probably buy a Linksys router instead. I had this since end of 2015, hoping it would solve some of the same problems I had with a WNDR3700. Needless to say, it hasn't.
- Retired_MemberMar 02, 2016
Good Luck!
- Mike_DemlerMar 03, 2016Aspirant
Here is the latest (March 2)
My latest set of problems began immediately after I rebooted my PC. I could no longer connect via Wi-Fi, and i then discovered that our entire LAN was down. At first, that even included the direct Ethernet connections.
When the direct connections came back up a short time later (at full speed), the Wi-Fi connections still provided no access at all to the Internet. That went on for a few hours, but eventually I was able to see a connection at only 0.2Mbps on my wife's PC. By this morning, that speed had increased to ~10-15Mbps, while I am still getting 90Mbps on my Ethernet link. Her PC is no more than 15 feet from the router.
This afternoon, I tried a test to see if your streaming QoS feature had anything to do with the speed anomaly. I setup her PC to stream a movie from Amazon Prime, which periodically got interrupted with warning messages of Internet problems. After ~2 hours, however, lo and behold her Wi-Fi link is now up to full speed!
Is the R7000 WiFi router adaptive and self-healing?
Don't get too excited though.
At exactly the same time, I have been testing my laptop PC, which is even closer to the router.. no more than 10 feet. It is only getting ~7Mbps on its Internet link, but that link is actually not 100% working.
I did a ping from my laptop to google.com, and I get a normal response: 17mSec for a reply.
But when I ping microsoft.com, as well as other sites, I get "Request Timed Out". What!??
Why is the router blocking access to some sites???
