Cocoq
Jul 25, 2021Follower
Nighthawk AC2300 shows wireless devices as a connected to network as wired how to fix
Sort By
You didn't give us muc to go off.
1. what router do you have? AC2300 is a speed.
2. firmware on the router?
3. what modem/gateway is it connected to?
4. are you using any range extenders, switches, access points in your network? If so, what ones and how is the network setup?
... and where are you looking that shows this?
Mobile app? Android? iOS?
Browser graphical user interface?
Desktop app for your operating system?
