DM8's avatar
DM8
Follower
Sep 23, 2019
Nighthawk AC2300
I need help help help!!! I’m trying to establish my new router using the netgear app and I cannot get past admin password.
  • plemans's avatar
    the defaults are
    login: admin
    password: password
    If someone owned it prior or it was a returned product, someone might have changed them already. If this is so, try factory resetting it (push and hold reset for 7-10 seconds while powered up)
    here's your support site with manuals, firmware, and install guides. It should have the option to login to the router manually and not using the app if you'd like to try that.
    https://www.netgear.com/support/product/AC2400.aspx
  • michaelkenward's avatar
    michaelkenward
    Your subject says AC2300, but the "footer" says AC2400. Which is it?
    AC2300 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
    There is an AC2400 but no AC2300.
