Charger_rules
Apr 24, 2021Aspirant
Nighthawk ac2600 and app not connecting even though i am on its wifi network
I'm not a big tech guy but we just bought a nighthawk ac2600 today and I hooked it all up and set up the network (changed name and passowrd) connected to it from my phones wifi with mobile data turned...
Charger_rules
Ok right now the only internet I'm connected to on this phone is through the wifi from this router, I open the app, it says checking internet connection, then goes to detecting product, then says there are issues connecting with go to settings wifi, that takes me to where I connect to the network I'm already connected to, it's a big run around and theres not much to do that doesn't lead right back to that.
The model is R7450
Also the things you said to click on don't seem to have links attached to them
The model is R7450
michaelkenward
Apr 24, 2021Guru - Experienced User
If there is one, what is the modem in front of your router?
They aren't supposed to. They are where to look in Windows. This isn't the place for tutorials in how to deal with Windows networks, but sniff around for something like this.
Windows Network Status
