jmass77651
Nov 01, 2020Aspirant
Nighthawk ac2600 app installation on second device
I tried installing the app on my new phone and got to the login page where it says admin and password, And default is password so why“ password and it tells me it is wrong. It says username admin and ...
Christian_R
Nov 05, 2020NETGEAR Employee Retired
Hello jmass77651,
Were you able to log into the Nighthawk app? I would suggest a factory reset on the router so that you're able to use the default credentials to login.
Christian
- jmass77651Nov 14, 2020Aspirant
Thank you Christian, but no! I didn't want to factory reset but it's looking like I will have to get up in the attic and find my box lol. Thanks again for your advice!!
Johnny
- michaelkenwardNov 15, 2020Guru - Experienced User
jmass77651 wrote:
.... it's looking like I will have to get up in the attic and find my box lol.
Can you access your box from the desktop genie or any other device?
If so, you may be able to reset the thing without having to crawl around in the attic.
- Settings
- Advanced
- Administration
- Backup Settings
- Erase
