Jambo1907's avatar
Jambo1907
Follower
Aug 29, 2016
Nighthawk AC2600 genie app not working
D7800 Vdsl version connected to talktalk fibre
Firmware updated on arrival yesterday and factory reset performed post update
All working fine and login via routerlogin.com
Genie app login fails "router not found or supported"
Not using guest network or IPv6 and D7800 listed in supported routers
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Jambo1907,
    1. Have you tried using another device (another computer, smartphone, tablet)?
    2. What version of the NETGEAR Genie app/program are you using?
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Jambo1907,
    I would like to follow up and check if you are still experiencing the issue.
    Dexter
    Community Team
