millewg001
Jul 21, 2020Aspirant
Nighthawk access to EX8000
I have an RAX120 installed connected to Spectrum with 100mbps services. This router is fairly new and appears to be relatively stable and provides good performance. I have an EX8000 extender connec...
michaelkenward
Jul 22, 2020Guru - Experienced User
Which products support the NETGEAR Nighthawk app? | Answer | NETGEAR Support
AP mode can break various features on routers, perhaps also on extenders.
You may need to find the IP address of the extender and use that as a way to get at its controls.
millewg001 wrote:
I am under the impression I should be able to manage both my RAX120 and my EX8000 through the Nighthawk app. Am I missing something?
The manual, not always accurate, for the EX8000 makes no mention of access through the app.
