sdegan05
Dec 12, 2022Aspirant
Nighthawk android aplication not connecting outside network
I have a Nighthawk RAX54 (AX6) and the android application on the phone but I cannot connect to the router if I am outside the wifi network. This was previously working. I have the latest version of ...
sdegan05
Dec 13, 2022Aspirant
The version I have is 2:21.1.2602.
I tried to activate 'Access anywhere' but when I go back it deactivates itself.
I can't still access the router over the internet. Should I uninstall the application and then try to reinstall it?
Thank you
- sdegan05Dec 13, 2022Aspirant
I have installed and uninstalled the application 3 times without success. Does anyone have a clue about how to solve this problem?
Thanks
- michaelkenwardDec 14, 2022Guru - Experienced User
Thanks
It could be something specific to the RAX54.
You could try this issue in the appropriate section:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
Which firmware version are you on?
- sdegan05Dec 15, 2022Aspirant
The router version is Firmware Version V1.0.11.112_2.0.77. I do not see any prompt for a version update.
Thank you
