undermark5
Aug 02, 2018Aspirant
Nighthawk Android app requesting Super user access
I just received an update to the app (though I didn't know it at the time) and while just using my phone normally for other tasks, a super user prompt came up for the nighthawk app. Why is this app no...
DarkusRattus
When you see the app requesting superuser access, you can assume the device is rooted.
I'm getting the same issue today. The app has requested superuser priveledges at least once a minute since it updated. There's no reason it should be requesting these permissions.
schumaku
Aug 03, 2018Guru - Experienced User
Android does not know anything about a Superuser permission. Don't have the bigger picture on all factors can trigger your rooted device control App to raise the warning. I would imagine Netgear does not use any su or sudo, so a wild guess could be a lazy access to the Android device file system requesting to access or browsing the root file system / in some lazy way.
As standard Android is not affected (all this does not exist or is intentionally and for good reasons prohibited) I'd suggest you to contact [email protected]
