undermark5
Aug 02, 2018Aspirant
Nighthawk Android app requesting Super user access
I just received an update to the app (though I didn't know it at the time) and while just using my phone normally for other tasks, a super user prompt came up for the nighthawk app. Why is this app no...
michaelkenward
Aug 03, 2018Guru - Experienced User
undermark5 wrote:
I just received an update to the app ...
Which App version?
I just received 2.2.4.397.
Nothing has changed on the access front.
Android 8.0.0
- schumakuAug 03, 2018Guru - Experienced User
michaelkenward wrote:
undermark5 wrote:
I just received an update to the app ...I just received 2.2.4.397. Nothing has changed on the access front.
Correct, haven't spotted any changes here, too. The problem (if any) is not with Android Permissions - for these geeks with rooted phones (again, why ever) the Superuser App, a superuser access management tool for rooted Android devices. This App allows to grant or deny root permissions, or set it to ask each time. Why ever, some updated code might try to browse/access the root (/) file system, triggering this App notification.
- sakura_candyAug 03, 2018AspirantSeeing the same in the Orbi app here...
- michaelkenwardAug 04, 2018Guru - Experienced User
sakura_candy wrote:
Seeing the same in the Orbi app here...Again, nothing has changed here on the permissions front with the Orbi app version 2.2.0.363
Not even on the beta app I am using in some hardware tests.
