yatman60
Jun 14, 2023Star
Nighthawk Android App
The android version of the Nighthawk app isn't connecting to the CAX80 Router. Whenever you try and login it says the router is unreachable despite it actually finding the router on first launch wher...
Jun 14, 2023Guru - Experienced User
Be sure to disable WiFi Private IP address on the phone:
Also if your using a beta FW, possible that NG hasn't made the NH app compatible yet.
Try this and see:
If not, you'll need to wait till NG gets them working in sync.
yatman60
Jun 14, 2023Star
The iOS app works just fine so it has nothing to do with the firmware. Others seems to have reported a similar problem as well and they're on the stock firmware.
- yatman60Jun 27, 2023Star
The support team provided me a firmware 5.1.1.2 to fix the issue with 5g connectivity on xfinity / comcast however ever since that day, specifically, the Android app will not connect to the router. iOS works just fine as does the web so I don't know what's different inside the Android app that would not allow it to connect.
I've tried uninstalling, clearing the cache and data in the settings, and all the usual debugging steps for an android app and nothing works.
- KitsapJun 27, 2023Master
yatman60 wrote:The support team provided me a firmware 5.1.1.2 to fix the issue with 5g connectivity on xfinity / comcast however ever since that day, specifically, the Android app will not connect to the router. iOS works just fine as does the web so I don't know what's different inside the Android app that would not allow it to connect.
Recommend you try the community section dedicated to the Nighthawk Application here:
https://community.netgear.com/t5/Nighthawk-App/bd-p/en-home-networking-apps
A review of existing posts there could be helpful. A moderator will most likely move your post.
- FURRYe38Jun 28, 2023Guru - Experienced User
So it's possible that the NH app SW hasn't caught up to support this newer beta FW version for the CAX80 that NG gave you. SW and the FW seem to have ties to versions and such to work together.
I recommend keeping in contact with NG support to let them know what your seeing. I presume once the beta FW for the CAX80 has been marked stable and heads towards release, the NH app team will get both Apple and Android apps updated to fully support it. Give it some time.
I'll be checking this as well.
