MattMatt
May 27, 2019Star
Nighthawk App - Feature Request
I would like to have the ability to see the following in the Device Manager: List of allowed devices not currently connected to the network List of blocked devices not currently connected to the n...
schumaku
May 27, 2019Guru - Experienced User
MattMatt wrote:I would like to have the ability to see the following in the Device Manager:
- List of allowed devices not currently connected to the network
- List of blocked devices not currently connected to the network
And in those lists, I would like to be able to restore access to a given device even if it isn't currently connected to the network.
Fully agree - the Nighthawk App must give (almost) all management access options available in Advanced -> Security -> Access Control, but especially these two lists are missing.
MattMatt wrote:I would also like to be able to deny a particular device access to the network even if it has the password. Currently the only capability the router has is to block access to the Internet. I don't want to use a client separator or whatever. I want to block a device off the network completely even if they have the password.
At this point I'm more than confused - more something like up set - well, I always was when it comes to Netgear's consumer stuff.
IrvSp you have a R8000 or R8000P when the grey cells haven't failed - please check if everything from here is right!
I'm almost convinced that the Nighthawk App - Devices [Pause/Resume] does
- Turn on Access Control with Allow all devices to connect (if it wasn't not enabled before, and/or configured different), and
- Trigger the [Allow] resp. [Block] for that device in the Access Control
Confusion why? On one hand, my R9000 does show in the Access Control Help - and I'm almost convinced this is the same text used on all newer Nighthawk routers (but I hope to be wrong).
Access Control Help
You can use Access Control to allow or block computer or electronic devices from accessing your network. When a device is blocked, it would only be able to get an IP address from your router, but it won't be able to communicate with other devices, nor it would be able to connect to the Internet.
On the other hand, How do I use access control to allow or block devices from accessing the Internet on my Nighthawk router? does state
Note: Blocking devices with access control only blocks them from accessing the Internet. Devices can still access your router’s local network and communicate with your connected devices.
This article applies to:
Wireless AC Router Nighthawk (11)
More hands? Here we go. How do I block a device on my network using the Nighthawk app?
To block a device on your network:
- Connect your mobile device to your router’s WiFi network.
- Launch the Nighthawk app.
- Enter your router’s admin password and tap the SIGN IN button.
The dashboard displays. - Tap Device List.
- Tap the Pause/Resume slider to block a device from your network.
Wireless AC Router Nighthawk (2)
Somehow left and right hand don't know what they do. Can't get rid of the impression that what appears to be the "same" feature is implemented very different on the routers. Christian_R can you shed some light into this mess please?
- MattMattMay 27, 2019Star
Thanks for the reply.
Currently if I "Pause" a device in the Nighthawk app that device still has access to the internal network, i.e. all of the computers on the network. I tested this yesterday when I disabled my son's access but he needed to copy some documents off my server. He still had access to the server on the internal network and was able to copy those docs.
- IrvSpMay 27, 2019Master
IrvSp you have a R8000 or R8000P when the grey cells haven't failed - please check if everything from here is right!OK, here is what I did... see the screen capture on left.
I BLOCKED my phone from connecting. The PHONE IS blocked. The Wireless icon is still there, but there is a 'small' ! to the right. Phone IP Address is 165.0.0.2? Tried to use the web, it says it is BLOCKED BY THE ROUTER ACCESS CONTROL..
On my R8000!!!
When I then ALLOWED it, phone wireless access returned.
- schumakuMay 27, 2019Guru - Experienced User
IrvSpthank you for joining! As a second test, may I kindly ask you to "Pause" any device from the Nighthawk App - and then check of this does lead to the same result as using [Block] in the Web UI Access control - or if it does _only_ stop the Internet access, but continues to allow the access to the same [W]LAN - as documented (and applicable for the R8000!) -> https://kb.netgear.com/24830/How-do-I-use-access-control-to-allow-or-block-devices-from-accessing-the-Internet-on-my-Nighthawk-router ?
To compare, the R9000 here does block both - so using the Access Control - Block/Allow does exactly reflect the Allow/Pause from the App.The small (!) does indicate the device (phone) isn't able to reach the Internet - that's OK and expected.
schumaku wrote:IrvSpthank you for joining! As a second test, may I kindly ask you to "Pause" any device from the Nighthawk App - and then check of this does lead to the same result as using [Block] in the Web UI Access control - or if it does _only_ stop the Internet access, but continues to allow the access to the same [W]LAN - as documented (and applicable for the R8000!) -> https://kb.netgear.com/24830/How-do-I-use-access-control-to-allow-or-block-devices-from-accessing-the-Internet-on-my-Nighthawk-router ?
Kurt, that small ! does mean I don't have any connection. Somehow the phone's IP Address changed to a real odd one like I said, but since it seemed to think I had a wireless connection, which I did not, it never reverted to the cell service...
So to do what the 2nd test was I opened my iPad's NightHawk app and paused the same phone. This time 'slightly' different results...
First, the Nighthawk app Device screen significantly changed? We've got 2 Android phones, both are set to show a phone icon AND individual device names. Now I paused my phone. Screen circles and rebuilds, comes back with MY phone in the pause position, BUT, and this is the odd part, my phone name changed to Android and a bunch of alpha-numerics, AND so did my wife's Android? Odd that BOTH would change? Oh well. I checked the phone, and unlike the time blocking it for the Browser Genie, it did NOT change the IP Address of 192.168.1.4? Oh? Interesting, but I could not use the Chrome browser as it never connected to anything, nor show me the blocked message? However, when I tried to open NIGHTHAWK app it couldn't? Said I could not connect to the SSID (5-2 Ghz) it was on? Could it be because the iPad was connected I though? So I turned back on the Android Phone. NightHawk on the iPad refreshed and both Android Phone names came back (why would pausing one Android phone change the name of both?). OK, phone now works browsing and still has the same IP Address. Great. With the Nighthawk app still on on the iPad, I opened it on the Android phone. It opened, logged in to the R8000 and works?
My conclusion? I don't care what the documentation says (when should one ever trust NG help or documentation that probably never changes with firmware updates or new/changed mobile apps), as far as I can tell, BLOCK and PAUSE do the same FUNCTION, STOPS ALL ACCESS TO THE LAN...
So I wanted to VERIFY this more, I used the iPad to PAUSE (via iPad's NightHawk) my PC, the very one I'm writing this on. First thing I did was open a CMD prompt and did a NET VIEW:
C:\>net view
System error 6118 has occurred.The list of servers for this workgroup is not currently available
Sort of verifies I am NOT on the LAN... and then I noticed on the Browser where I'm writing this a RED bar telling me the AUTOSAVE failed?
Ok, took off PAUSE and check NET VIEW:
C:\>net view
Server Name Remark---------------------------------------------
\\IRV8700 Irv's 8700
\\LARAINE-XPS8500 Laraine's XPS8500
\\READYSHARE readyshare
The command completed successfully.Also as I type this the AUTOSAVE is working again.
Soooo.... I think I can safely say BOTH BLOCK and PAUSE do the same function, disconnect the device from the LAN.
I would think though if other routers have a different operational mode, like you can only block Internet access, that might not be true, but it is sure more work for the CPU/router to keep track of who has Internet access and who doesn't? On the other hand, the OP claims they didn't have the same results I did? OP claims to have an R8000 like I do too? I am on V1.0.4.28_10.1.54, could OP be on a different F/W?
In any case, it seems NG documentation if FUBAR'ed?
On my R8000!!!
My guess is that the phone will default to cellular when it cannot access the Internet. Can you confirm that setting is disabled?
What I can tell you all, confirmed just now, is that hitting 'pause' on the app for my desktop cause the "This Device Is Blocked..." from the R8000. But a simple click brought up the shared directories on my Windows Server. I don't have Wireless Client Separation enabled (I seem to remember that setting on a router, but at the moment I can't put my hands on that setting), not that it would matter as both my desktop and the server are on a wired connection.
So, don't know what to tell you. Pause doesn't block someone from the local network. Not on my LAN anyway.
