MattMatt
May 27, 2019Star
Nighthawk App - Feature Request
I would like to have the ability to see the following in the Device Manager: List of allowed devices not currently connected to the network List of blocked devices not currently connected to the n...
IrvSp
May 27, 2019Master
schumaku wrote:
MattMatt wrote:I would also like to be able to deny a particular device access to the network even if it has the password. Currently the only capability the router has is to block access to the Internet. I don't want to use a client separator or whatever. I want to block a device off the network completely even if they have the password.
At this point I'm more than confused - more something like up set - well, I always was when it comes to Netgear's consumer stuff.
IrvSp you have a R8000 or R8000P when the grey cells haven't failed - please check if everything from here is right!
OK, here is what I did... see the screen capture on left.
I BLOCKED my phone from connecting. The PHONE IS blocked. The Wireless icon is still there, but there is a 'small' ! to the right. Phone IP Address is 165.0.0.2? Tried to use the web, it says it is BLOCKED BY THE ROUTER ACCESS CONTROL..
On my R8000!!!
When I then ALLOWED it, phone wireless access returned.
MattMatt
May 28, 2019Star
On my R8000!!!
My guess is that the phone will default to cellular when it cannot access the Internet. Can you confirm that setting is disabled?
- MattMattMay 28, 2019Star
What I can tell you all, confirmed just now, is that hitting 'pause' on the app for my desktop cause the "This Device Is Blocked..." from the R8000. But a simple click brought up the shared directories on my Windows Server. I don't have Wireless Client Separation enabled (I seem to remember that setting on a router, but at the moment I can't put my hands on that setting), not that it would matter as both my desktop and the server are on a wired connection.
So, don't know what to tell you. Pause doesn't block someone from the local network. Not on my LAN anyway.
- schumakuMay 28, 2019Guru - Experienced User
MattMatt wrote:What I can tell you all, confirmed just now, is that hitting 'pause' on the app for my desktop cause the "This Device Is Blocked..." from the R8000. But a simple click brought up the shared directories on my Windows Server.
I suspect the Pause / Device block does deny _new_ sessions on some implementations?
For https Web pages, you get the "This device is Blocked..." message, too?
MattMatt wrote:I don't have Wireless Client Separation enabled (I seem to remember that setting on a router, but at the moment I can't put my hands on that setting), not that it would matter as both my desktop and the server are on a wired connection.
No such control for the "primary" wireless, available only on the Guest networks for the Nighthawk Routers.
MattMatt wrote:So, don't know what to tell you. Pause doesn't block someone from the local network. Not on my LAN anyway.
I remember, you had some questions about reading between the lines. It looks to me like established sessions (at least to the LAN) might remain available - so when you worked with your desktop before, the sessions are established, the Windows server name might be cached anyway, so that's why you can continue accessing the Windows Server even after Pause is selected.
When doing the similar test here on the R9000 on the primary WLAN - which does clearly state it does block any network connection - even established sessions to the NAS are stopped, no ping to any, ... as expected.
Now the curiosity came up and we connected a (Windows 10) test system direct to a router LAN port. And it behaved the same like the wireless above.
Needless to say, when using a port on the attached switch (an S8000/GS808E) here, the LAN connectivity to the switch ports can't be prohibited, except of the data flowing to the router switch port of course ... which behaves blocking as expected again.
At this point the bigger problem - even after resuming (allow network access again) the DNS caching does still bring us to the "This device is blocked" (for http, port 80) resp, a "dead end" (for https, port 443). So either flushing DNS cache or reboot is the way to re-establish connectivity and full usability.
- IrvSpMay 28, 2019Master
MattMatt wrote:I BLOCKED my phone from connecting. The PHONE IS blocked. The Wireless icon is still there, but there is a 'small' ! to the right. Phone IP Address is 165.0.0.2? Tried to use the web, it says it is BLOCKED BY THE ROUTER ACCESS CONTROL..
On my R8000!!!
I think the Phone still thought it was connected to the router, it never itself disconnected. The SSID is still SEEN, but it can't connect. It is set to connect to it when it sees the SSID. The fact that it can't connect may have it continually retrying, so it WILL not switch to cell service.
Same goes for my iPad and PC. That is also why once the block/pause is removed the connection is automatically restored.
Maybe different phones operate differently?
All I know is that not what devices, phone, iPad, or PC, is denied access, it has NONE. No app, program, nor Windows command, can assess ANY LAN resources.
