rpmurph8300
Aug 21, 2021Apprentice
Nighthawk App Access Control Not Working (App Version 2.11.0.11)
It seems there may be an issue with the latest release of the Netgear Nighthawk App for iOS or maybe the netgear APIs. Along with getting a Device Offline - CDIL-API-FAIL after rebooting, I am notici...
DarrenM
Aug 30, 2021Sr. NETGEAR Moderator
We have a bug capture built into the nighthawk app. What you need to do is replicate the issue you are having and when you see the error message in the app shake your phone side to side this should pop up a tool to allow you to report the issue and it will capture what is happening.
DarrenM
- rpmurph8300Aug 30, 2021Apprentice
I did that twice over the weekend so hopefully that will help speed up the fix for this
