DEBAMN1281
Mar 05, 2023Follower
Nighthawk app admin log in
I recently changed my Netgear router admin log in password via routerlogin.net and now I'm unable to login on the Nighthawk app with that log in or the default (password) which makes the app unusable...
michaelkenward
Mar 07, 2023Guru - Experienced User
The Nighthawk app needs a multi-stage login.
First you connect to the local WiFi, then you login to Netgear's "Anywhere Access" cloud service with your username and password for that, then you login to the router.
It isn't easy to understand what is happening at your end. Things like "unable to login" don't tell us what you are logging into and what messages you get.
