CFC
Jan 30, 2021Tutor
Nighthawk App and Admin Password Issue
I did the recent software update and then had password access issues with wifi extender. After many attempts, I factory reset the wifi extender and was able to re-establish connectivity to my network...
CFC
Jan 31, 2021Tutor
Sorry, but I don't follow your comments. Everything was followed per the netgear instructions. On the PC it was fine. The App is the issue. It blocks me at the admin stage looking for a password that I never really set to my memory. But the reset should have returned it to lc password based upon the reset button. I just do not get why the App is acting differently from the PC logon.
Graemeh12937
Jan 31, 2021Initiate
I am having the same problem with the App. I can log in to my extender via the web without problem but the app just keeps telling me the admin login and password are wrong, even though I know what they should be. It just seems to be stuck in a loop.
The extender works well, but the app is very frustrating
- Graemeh12937Jan 31, 2021Initiate
When I tried to reinstall the app it now tells me it cant connect to the extender network - what is going on?
- smitfitsFeb 22, 2021TutorI’ve had this problem multiple times as soon as I think I figured it out it will do it again. Once router Access Control settings blocked the phones MAC Address. Tonight the 2 step Authenticator couldn’t be turned off and froze every time I tried.
- CFCMay 11, 2021Tutor
Actually, it is a big deal. I did everything that you suggested and I was able to reset the extender, at the extender. The issue is that Netgear or Nighthawk did a APP software update which I accepted and after that, it keeps blocking full access when using the APP, e.g. keeps asking for an Admin PW which I have never set and doesn't exist as far as I am concerned. Honestly, the abject lack of support from Netgear to acknowledge that their update messed up the phone app will keep me from buying anything from them again. Sometimes a customer has to walk rather than being treated like this. Check the other comments, a lot of people have had this problem but they are tone deaf towards addressing it. Thanks for trying Mike 1212, though.
