CFC
Jan 30, 2021Tutor
Nighthawk App and Admin Password Issue
I did the recent software update and then had password access issues with wifi extender. After many attempts, I factory reset the wifi extender and was able to re-establish connectivity to my network...
smitfits
Feb 22, 2021Tutor
I’ve had this problem multiple times as soon as I think I figured it out it will do it again. Once router Access Control settings blocked the phones MAC Address. Tonight the 2 step Authenticator couldn’t be turned off and froze every time I tried.
CFC
May 11, 2021Tutor
Actually, it is a big deal. I did everything that you suggested and I was able to reset the extender, at the extender. The issue is that Netgear or Nighthawk did a APP software update which I accepted and after that, it keeps blocking full access when using the APP, e.g. keeps asking for an Admin PW which I have never set and doesn't exist as far as I am concerned. Honestly, the abject lack of support from Netgear to acknowledge that their update messed up the phone app will keep me from buying anything from them again. Sometimes a customer has to walk rather than being treated like this. Check the other comments, a lot of people have had this problem but they are tone deaf towards addressing it. Thanks for trying Mike 1212, though.
