Jarisma
Jun 08, 2020Aspirant
Nighthawk App and Multiple Routers
I have 2 houses. One in NJ and one in PA - both houses have the same routers - a Nighthawk AC1900 - both routers are up to date on firmware and they always perform well. I recently downloaded the ...
michaelkenward
Jun 10, 2020Guru - Experienced User
First AC1900 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Second, have you set up remote management on both routers?
Is the Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0 listed in your footer involved in this in anyway? Or did you just click the first thing that popped up when you wrote your message?
- JarismaJun 10, 2020Aspirant
Hi Michael - thank you for replying. I have a Netgear Nighthawk - AC1900 Smart WiFi Router Model R7000. I am pretty sure I set up both routers the same exact way. I cannot check the PA router at this time to verify.
- michaelkenwardJun 10, 2020Guru - Experienced User
Yes, but did you set them both up with remote management enabled? That is the crucial step.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.See the section Remote Management.
