Jarisma
Jun 08, 2020Aspirant
Nighthawk App and Multiple Routers
I have 2 houses. One in NJ and one in PA - both houses have the same routers - a Nighthawk AC1900 - both routers are up to date on firmware and they always perform well. I recently downloaded the ...
Jarisma
Jun 10, 2020Aspirant
Hi Michael - thank you for replying. I have a Netgear Nighthawk - AC1900 Smart WiFi Router Model R7000. I am pretty sure I set up both routers the same exact way. I cannot check the PA router at this time to verify.
michaelkenward
Jun 10, 2020Guru - Experienced User
Yes, but did you set them both up with remote management enabled? That is the crucial step.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
See the section Remote Management.
