Skiminims
Mar 24, 2021Follower
Nighthawk app and setting time limits?
I just bought the R6350 AC1750 router and for the life of me I can't figure out how to set internet time limits using the nighthawk app. I can manually turn devices off and on, but I want to set a bedtime schedule. It's my understanding that it was possible with the app. On the apps page (https://www.netgear.com/home/services/nighthawk-app/), under #4 it has:
"Smart Parental Controls Easily manage content & time online with Circle® Smart Parental Controls."
How do I get to this feature? My device manager right now is very limited to just off and on.
Any help is greatly appreciated!
- Christian_RNETGEAR Employee Retired
Hello Skiminims,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
- JamskiAspirant
Did you get an answer to this time limit? I am having the same issue right now
You need to set any scheduling using the routers web page. Not thru the NH app.
