BMS99
Nov 13, 2022Follower
Nighthawk app broken
This app seems to be constantly failing on me. The error message is “Logon Timed Out”. I have reset everything several times and uninstalled and reinstalled the app. I guess the only way to update the...
michaelkenward
Nov 14, 2022Guru - Experienced User
Check these conversation:
Nighthawk App Logon Timeout - NETGEAR Communities
Can't logon to Orbi - "Logon timed out, please try... - NETGEAR Communities
They are just two of the oldest and longest running conversations in this saga.
We are all waiting for Netgear to fix the apps.
In the meantime, use the browser graphical user interface (GUI) as far as possible.
How do I install my NETGEAR router using the router web interface? | Answer | NETGEAR Support
