InstantPOT
Oct 09, 2019Follower
Nighthawk app cannot find installed router..
loaded/removed the Nighthawk app three times from the google store. My phone is connected to my R6700 router (correct SSID) as confirmed through the phone wifi setting, yet the Nighthawk app scans a...
DexterJB
Oct 11, 2019NETGEAR Moderator
Hi InstantPOT, welcome to the community! Is the R6700 set to router mode or AP mode? Please make sure that it is set to router mode.
Dexter
schumaku
Oct 12, 2019Guru - Experienced User
Please note that only the newer R6700v2 (R6700-200xxx) and R6700v3 (R6700-300xxx) are supported by the Nightawk App. The initial R6700 (R6700-100xxx) model can only be used with the Genie App. Check your router product label on the bottom for the exact model version.
