csullivan247
Aug 04, 2022Follower
Nighthawk App Cannot Find Router
Hey everyone! I connected a Nighthawk AX6 Wifi Router (Model RAX45) to a Century Link modem. Internet is working just fine but I can't change the SSID or password. Netgear says the best way...
michaelkenward
Aug 04, 2022Guru - Experienced User
Which Century Link modem?
Is it a modem/router by any chance?
Another option provided by Netgear is to go to http://routerlogin.net and enter the router's default username and password. When I navigate to that web address it tells me that to gain access my device must be connected to the router or access point's WiFi network. Again, I am already connected to the router and using the internet provided through it.
That isn't a "web address" so much as the way into the browser graphical user interface (GUI) for your router. For many people it is the best way to manage thing. Apps are the devil's plaything.
The easiest way in is with a PC wired to one of the router's LAN ports. Then use that address or http://192.168.1.1.
It is in the manual:
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Begin with the Quick Start/Installation Guide.
