csullivan247
Aug 04, 2022Follower
Nighthawk App Cannot Find Router
Hey everyone! I connected a Nighthawk AX6 Wifi Router (Model RAX45) to a Century Link modem. Internet is working just fine but I can't change the SSID or password. Netgear says the best way...
Aug 04, 2022Guru - Experienced User
If you're on iOS make sure to disable icloud relay and private mac/ip address. that can mess up the app connection
