TamZZ's avatar
TamZZ
Follower
Jul 31, 2020
Nighthawk App can't find devices with R7000P router
Last week I was using this App just fine. Tonight, my Nighthawk app can't find my devices. It sends me to the admin login and I can't log in. What is going on? I've uninstalled and installed the app several times. Please help. Thank you.
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Not much to go on there.
    Is this access through the local wifi? Does that login OK?
    Or is it remote access?
    What does this mean?
    Do you get some sort of error message? "can't log in" could mean many things.
    What firmware version do you have on the R7000P?
    A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
    It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
    The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
