R7800HelpMe
Sep 21, 2023Aspirant
NightHawk App Can't see R7800 Router
Ok, I have done a factory reset on my router. My android phone I've installed the Nighthawk App. I'm stuck in a loop where it keeps telling me "Router Not Found". I've done the suggestions about WiFi...
michaelkenward
Sep 21, 2023Guru - Experienced User
R7800HelpMe wrote:
I tried logging into routerlogin.net and routerlogin,com. Can't access my router setting or even get to the login screen to change the name and other settings.
Is that on the mobile device or with a wired link to the browser graphical user interface (GUI)?
A number is more useful than "the latest". There may be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
If there is one it might help if you told people the make and model number of the modem/gateway/ONT that sits between this router and the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
R7800HelpMe
"If there is one it might help if you told people the make and model number of the modem/gateway/ONT that sits between this router and the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?"
I don't have a modem. Fiber Optics.
- michaelkenwardSep 21, 2023Guru - Experienced User
Some fibre services come with a box that also does routering. The idea is to have just one box at the consumer end.
- R7800HelpMeSep 21, 2023Aspirant
The only box I see in the basement has a power backup on it. I didn't see a reset button anywhere on it. I might add that I've had this router in use for about 5 years without issue until I couldn't access it through the App. I can't access it through a web browser like I stated before. I used to be able to access it through a web browser without issues in the past up until now.
Does which browser is used to access the admin router settings make a difference?
Not normally, but browsers are getting increasingly picky about the sites they will visit.
They hate http addresses. They prefer https, but that is unnecessary for local access from your own network.
It always helps to try every browser that you can lay your hands on.
