R7800HelpMe
Sep 21, 2023Aspirant
NightHawk App Can't see R7800 Router
Ok, I have done a factory reset on my router. My android phone I've installed the Nighthawk App. I'm stuck in a loop where it keeps telling me "Router Not Found". I've done the suggestions about WiFi...
R7800HelpMe
I don't have a browser interface. All the links and IP logins don't work. I've used Edge and DuckDuckGo without success. Can't access the router Admin settings through any of their suggested sites.
michaelkenward
Sep 21, 2023Guru - Experienced User
I don't know what that means.
By default the R7800 has its own default IP address, 192.168.1.1.
routerlogin.net is another address, but that gets translated in the router.
If there is something in front of the router, that may decide to avoid clashes and squat on an address something like 10.X.X.X
- R7800HelpMeSep 21, 2023Aspirant
I have tried the routerlogin.net and it brings me back to the Netgear website. To which there is no choices to access my router settings. It's a perpetual loop. I've already performed a factory reset. Is that something I should do again?
- michaelkenwardSep 21, 2023Guru - Experienced User
What is "the Netgear website"? Does it have an address?
I've already performed a factory reset. Is that something I should do again?No harm in trying. But I doubt if it will fix anything.
The first thing to try is a wired connection to the GUI.
If you insist on using wifi, you could also disconnect the router from the rest of the network. You don't need an Internet connection to get into the GUI. If you did it would be impossible to set up these things.
How do I perform a wired connection and access the GUI? General User Interface? Thanks for your help, I do appreciate it.
