pseidel
Mar 28, 2021Follower
Nighthawk App device manager change
A few days ago, my nighthawk app(most current version) changed from a device list with switches to dis/enable devices to a new list with a white background. There are no switches anymore. I removed...
bhonaker
May 24, 2021Guide
This also happened to me. App is running on Android, app version is 2.9.6.1513. Router is RAX15 (which Netgear seems to no longer believe exists!? as I can't choose it in the model above)... and firmware version is 1.0.2.82.
PLEASE fix this. Note that on main screen 'Device Manager' shows 15 devices connect. But when I click the button it opens 'Devices' page, showing 'Home' profile with 0 devices.
Netgear Nightgear app broke this very solidly with the last app update. Please either revert your deployed app to the prior version or fix this IMMEDIATELY. It's badly broken.
- Christian_RJun 03, 2021NETGEAR Employee Retired
Hello,
We're hoping to release a new Nighthawk app version for Android soon. Please stay tuned!
Christian
- bhonakerJun 18, 2021Guide
You released a new vesrion of Nighthawk. I installed it and got nothing. Device Manager link takes a long time, then opens a page that just says 'Devices (0)'. Plus there is no firmware update for RAX15. I'm beginning to suspect there never will be again.
- michaelkenwardJun 19, 2021Guru - Experienced User
The database of "drop down" options is hopelessly out of date. Netgear doesn't seem to even try to maintain it.
Fortunately, the support database is more reliable.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.That'll take you here:
