Scoregon
Sep 30, 2019Initiate
NIGHTHAWK APP DEVICE MANAGER WONT SHOW DEVICES GIVES Sorry, the action was failed. Please try again
Everything else on the app seems to be working but when I try to see the devices connected I get the error message stating "Sorry the action was failed. Please try again." Firmware is the most cu...
DexterJB
Oct 01, 2019NETGEAR Moderator
Hi all, welcome to the community! If you've just recently updated the firmware of the router, we recommend doing a factory reset if you haven't yet. The link below may help.
http://kb.netgear.com/app/answers/detail/a_id/9665
Once the setup has completed, you can try and reinstall the app and let me know if the issue will persist.
Dexter
- ScoregonOct 02, 2019Initiate
Issue still persists for me.
- DexterJBOct 08, 2019NETGEAR Moderator
- miocevicdOct 16, 2019GuideI have the same issue. Haven’t been able to resolve it
- Zach701Apr 06, 2020AspirantStill happening to me also
- PathonMay 05, 2020AspirantAfter update says no devices. I tried reboot, reset, delete, new system and nothing Still. No help
- Turbo74May 05, 2020Aspirant
This is so very annoying! (and my kid keeps yelling at Fortnite too)
- dpwellerApr 17, 2020GuideDeleted the app. Did a factory reset. Re-installed the app and the problem is still there.
- jrmcqApr 17, 2020TutorApp is absolute garbage
- TonySkatesOct 12, 2020Aspirant
Hi
Same problem here. I bought it last Friday, installed it the same day and all appeared fine, the firmware version was V1.0.0.206 and it automatically updated to V1.0.0.210 although this did not happen smoothly!
The problem I have is intermittent, yesterday morning it found 6 devices 4 on 5 GHz and 2 on 2.4 happy days - or so I thought! However to get that far I’ve had to factory reset three times. While it was fine during the day by the evening nothing. Worse still it wouldn’t open the device part of the App, it wouldn’t do a speed test or much else really. I turned the WiFi off and then back on again and while the allowed me to click on Device Manager and the enter the device list it was still empty and also the speed test unavailable. BTW I’m only using the speed test as a method of seeing what’s available within the system.
So there we are NETGEAR it looks like someone somewhere hasn’t thought things through, causing your customers frustration and many wasted hours! Either it get sorted or it gets returned because I’ve got better things to do that reset Nighthawk every five minutes.
I’m using IOS
Cheers Tony
