Scoregon
Sep 30, 2019Initiate
NIGHTHAWK APP DEVICE MANAGER WONT SHOW DEVICES GIVES Sorry, the action was failed. Please try again
Everything else on the app seems to be working but when I try to see the devices connected I get the error message stating "Sorry the action was failed. Please try again." Firmware is the most cu...
RedWolfe
Oct 23, 2019Initiate
I have a R7000P giving me the exact issue. It's been driving me crazy for months now.
I updated the firmware.
Didn't fix it!
Did a factory reset.
Didn't fix it!
It occurs using both iOS (iPad Air 2 running iOS 13)and and Android (Samsung Note 9 running Pie) I have Uninstalled and reinstalled both apps on both devices multiple times, both before and after the factory reset. This leads me to believe that it is a setting that was tweaked in update to the app that needs an adjustment through the desktop. What that adjustment is has me spending hours looking online for a solution.
I have no issues with accessing the Device Manager on my computer, just using the app.
I am not an expert but I am a gifted amateur who has been building computers and tweaking software before Bill made his first billion. I don't believe in deleting the app to fix the problem, I want to fix it and use it.
Help me!
Didn't fix it!
Didn't fix it!
Help me!
miocevicd
Oct 24, 2019Guide
RedWolfe I spent almost 2 hours on the phone with customer support, but it looks like there is an issue with the new firmware. I rolled my firmware back to the previous version and it solved the issue.
Go to https://www.netgear.com/support/product/R7000P.aspx then Downloads, then expand View Previous Versions and download 1.3.1.44 or possibly even 1.3.0.20.
To manually upload the previous version, log in to your router and go to Advanced. Then go to Administration and then Router Update. Click Browse and find your firmware file and upload it. Hopefully that works for you, since it fixed my issue.
- schumakuOct 24, 2019Guru - Experienced User
DexterJB another product firmware image rushed out without serious QA testing. Brilliant! ChristineT one more for the complaints list...
- Ric123May 08, 2021AspirantI have same issues. On phone 3 hours and cameras are visible on my security screen but my phone app says Opps no devices detected. I have tried everything . Deleting app. Resetting. Please help
