Scoregon
Sep 30, 2019Initiate
NIGHTHAWK APP DEVICE MANAGER WONT SHOW DEVICES GIVES Sorry, the action was failed. Please try again
Everything else on the app seems to be working but when I try to see the devices connected I get the error message stating "Sorry the action was failed. Please try again." Firmware is the most cu...
Gu010206
Nov 01, 2019Aspirant
After update I can’t do device manager using the app...
- PigletRiderNov 19, 2019Apprentice
Gu010206 wrote:
After update I can’t do device manager using the app...What update? Was this a firmware update from the app and/or the web GUI?
When I go to the "Device Manager" tab, it comes back "No devices found!," which is strange since you have to be connected to even get this message.
This worked for me at one time. I don't know what happened. I did do the factory reset after I installed the latest firmware (v1.0.1.100).
Also, when I go to the "Support" menu, I get "No records found!" So the very mechanism I'm supposed to use to get support for this issue, is itself incapacitated due to some issue. Horrible!
Has anyone figured this out apart from a firmware downgrade?
- PigletRiderNov 23, 2019Apprentice
Has anyone gotten the "Device Manager" tab to actually show any connected devices using the v1.0.1.100 firmware, the latest Beta firmware? I'm on an iPhone 7 Plus running the latest iOS software (v13.2.3).
The Web GUI will show the 27 connected devices. The app on my iPhone shows "0" connected devices.
- PigletRiderNov 25, 2019Apprentice
PigletRider wrote:Has anyone gotten the "Device Manager" tab to actually show any connected devices using the v1.0.1.100 firmware, the latest Beta firmware? I'm on an iPhone 7 Plus running the latest iOS software (v13.2.3).
I just installed the latest iOS update (v2.4.12.4) for the Nighthawk app and NOTHING changed. The tabs all looked the same and I was still showing "0" devices in the "Device Manager" tab.
"This latest release includes some important bug fixes and improvements to the dashboard and device manager" so says the text associated with this app update. What???? I think getting the devices to actually show should be considered the biggest improvement, don't you, Netgear?
Yes. A ticket is opened with Netgear. I've heard nothing regarding it.
- Ric123May 08, 2021AspirantI have the same issue. Please help me
