Scoregon
Sep 30, 2019Initiate
NIGHTHAWK APP DEVICE MANAGER WONT SHOW DEVICES GIVES Sorry, the action was failed. Please try again
Everything else on the app seems to be working but when I try to see the devices connected I get the error message stating "Sorry the action was failed. Please try again." Firmware is the most cu...
mattrichards
Apr 01, 2020Guide
I have the same issue on my xr500 with firmware V2.3.2.56. What is the ETA on a resolution?
dpweller
Apr 14, 2020Guide
Same issue here as well. Since version 2.4.24.1 of the iOS app, device manager doesn’t work. I have not updated my router firmware so the only thing that changed was the NH App.
Please don’t ask me to create a support ticket because I did that over a week ago and your support people closed it even after I jumped through the hoops for them. Jerks!
- dpwellerApr 14, 2020GuideScreenshots of the exchange on my CLOSED case
- Lofty24May 14, 2020AspirantAfter updating my firmware, I too am not able to see the devices on my NG app ! This is insane . I had a couple of devices that I turned off from the NG app and now I have no way of getting internet on those devices . Rebooted and everything .
I also created a ticket and recd an email to call NG with a ticket # . I did and I was 37th (!!!!) in the queue ! The ticket# was supposed to “expedite “ my call , according to the outgoing message . Really ?- ReservoirDog83May 14, 2020TutorTo give internet access to your device you will have to do it from a browser, go to routerlogin.com and log in.
I had the same issue but it got resolved after they updated the app last week.
Good luck!- Lofty24May 14, 2020AspirantThanks ! I’ll try that .
- mmont00May 14, 2020TutorYeah, you should be able to log into the router through a browser and turn on all blocked devices.
Another bug I noticed was that when I first installed the router is that it saw my extender right away. After noticing that the signal from the router was strong enough and I didn't have to use the extender, I unplugged it. Then DumaOS did not allow me to delete the device because it "was still being used". I don't know how the router can "see" a non-powered unit and not let you delete it. I had to reboot the router and then it allowed me to delete. Seems that there are bugs everywhere - nighthawk app & DumaOS. Kind of dissapointing since I just bought it.
One last note to others on this chat. Set your options to not automatically update the firmware. I have learned in the past to never update firmware until it has been vetted for at least a few months. I bricked a WD device by having it automatically update and they had to send me a new one since it was under warranty.- Lofty24May 14, 2020AspirantIt worked ! Thanks again :)
And yes , I do not opt in to any automatic updates . Great advice !
- Ric123May 08, 2021AspirantHorrible customer service. On phone total 4 hours and mostly wait time and have me go through each step over and over. Still " opps no devices found on my android
