Scoregon
Sep 30, 2019Initiate
NIGHTHAWK APP DEVICE MANAGER WONT SHOW DEVICES GIVES Sorry, the action was failed. Please try again
Everything else on the app seems to be working but when I try to see the devices connected I get the error message stating "Sorry the action was failed. Please try again." Firmware is the most cu...
JC_Hammer22
May 01, 2020Initiate
Just updated the app and says I have no devices connected when clearly I do ... you had one job Nighthawk app just one
- JJB651May 01, 2020GuideI have the same problem no device connected and it’s very slow after updating the app. NETGEAR PLEASE WE NEED A UP TO DATE APP!!!!
- Mprussell74May 01, 2020TutorThe app won’t let me log in anymore. Still can log in through app on iPad that I did not upgrade.
- JJB651May 01, 2020GuideNETGEAR PLEASE UPGRADE THE APP!!!!
- SynakulMay 02, 2020Aspirant
I thought i was the only one, it was working a week ago and now when i go to device manager it says 0 devices found.
- seeilerMay 02, 2020GuideSame...I got on the app to turn a device on and it said it needed to be updated so I did and now my device shows connected with problems and no devices show as connected on the app. I’ve tried powering off and on, logging in and out, but so far nothing has helped. This is absurd. I wasn’t having any issues until I did the update on my phone.
- ApplegMay 02, 2020Initiate
I am so over with Netgear. I also was forced to upgrade the Nightawk app and immediateli all connected devices were remove. I did a factory reset on the router, uninstalll and re-install the app and the same issue is being repeated. I am ready to pull my hair out because it is one issue after another. The funny part about the support team, everyone has a different resolution, which i think is a trial an error tactic that is being used. Lets give a resolution and it if fixes the issue whoop-de-do. Netgear, I need my connected device to display on my app.
Frustrated,
Appleg
- Mprussell74May 02, 2020Tutor
This is not the first time this has happened. I wish I had remembered to check first.
- tolson37May 04, 2020Aspirant
I've got the same issue now too. The nighthawk app on my iphone 11 pro stopped showing all the connected devices. I really used this alot to shutdown my daughters devices at certain times. I tried deleting the app and re-installing. rebooting my router too...
I can get to the devices by logging in via my macbook pro thru safari just fine.
Seems like it just happened with the latest release of the apple Nighthawk app.
