Scoregon
Sep 30, 2019Initiate
NIGHTHAWK APP DEVICE MANAGER WONT SHOW DEVICES GIVES Sorry, the action was failed. Please try again
Everything else on the app seems to be working but when I try to see the devices connected I get the error message stating "Sorry the action was failed. Please try again." Firmware is the most cu...
Appleg
May 02, 2020Initiate
I am so over with Netgear. I also was forced to upgrade the Nightawk app and immediateli all connected devices were remove. I did a factory reset on the router, uninstalll and re-install the app and the same issue is being repeated. I am ready to pull my hair out because it is one issue after another. The funny part about the support team, everyone has a different resolution, which i think is a trial an error tactic that is being used. Lets give a resolution and it if fixes the issue whoop-de-do. Netgear, I need my connected device to display on my app.
Frustrated,
Appleg
Mprussell74
May 02, 2020Tutor
This is not the first time this has happened. I wish I had remembered to check first.
