Scoregon
Sep 30, 2019Initiate
NIGHTHAWK APP DEVICE MANAGER WONT SHOW DEVICES GIVES Sorry, the action was failed. Please try again
Everything else on the app seems to be working but when I try to see the devices connected I get the error message stating "Sorry the action was failed. Please try again." Firmware is the most cu...
mirand76
May 02, 2020Initiate
Issue with Nighthawk App iOS version 2.5.0.47, on app Device Manager shows No device found! Before Nighthawk App updated to this version 2.5.0.47, Nighthawk App showed Device Manager devices. After App updated, it is not working on any iOS device. Can't revert to order version Nighthawk version, which was working before App update. Updated iOS device OS, same issue. Tried on NOT updated Nighthawk iOS device and still works until App updates. It is the Nighthawk App update the issue. AC2100 Device have the latest firmware update and Nighthawd App previous version Device Manager on App was working. It is not the AC2100 device firmware. Netgear needs to revise Nighthawk App for iOS and fix it. the only reason why I use and like Nighthawk App is that I can see the connected devices on any iOS device and Android device. I haven't checked on an Android device to see if there is the same issue with the Nighthawk App.
seeiler
May 02, 2020Guide
I’m hoping for some resolve soon and will likely only get answers from those of you that still have support. My router is past the date of any support options so I can’t get help from them. Glad I’m not alone, but this is super annoying!
