Scoregon
Sep 30, 2019Initiate
NIGHTHAWK APP DEVICE MANAGER WONT SHOW DEVICES GIVES Sorry, the action was failed. Please try again
Everything else on the app seems to be working but when I try to see the devices connected I get the error message stating "Sorry the action was failed. Please try again." Firmware is the most cu...
Ll627pro
May 03, 2020Aspirant
I just updated nighthawk to version 2.5.0.47. Device manager no longer detects any device. Reboot router, reinstall app does not help. Called tech support and he needs to get on my computer. Rejected.
seeiler
May 03, 2020Guide
Obviously it’s an app issue so you’ll have to use a different route to control devices. In my situation, I had the fire stick turned off and then updated the app and could no longer see connected devices on the app or have the ability to manage them. I used the routerlogin.net page to access my router info and it showed me all of my devices so I was then able to unblock and allow my fire stick access. I’ve at least been able to manage my biggest concern which was being able to use the internet on my devices, however the app is still messed up so hopefully they will get to fixing any issue soon. At least I can use the internet on my devices now.
