Scoregon
Sep 30, 2019Initiate
NIGHTHAWK APP DEVICE MANAGER WONT SHOW DEVICES GIVES Sorry, the action was failed. Please try again
Everything else on the app seems to be working but when I try to see the devices connected I get the error message stating "Sorry the action was failed. Please try again." Firmware is the most cu...
mattrichards
Apr 01, 2020Guide
I have the same issue on my xr500 with firmware V2.3.2.56. What is the ETA on a resolution?
Jrzygrl
May 05, 2020Aspirant
Same here it's so annoying .
- HomeITgotoguy3May 05, 2020Tutor
So how do I get the older version for my IPhone?
- SoCalProfMay 05, 2020Tutor
There may be other ways, but as far as I know the only way is to find an old iPad or iPhone that has an earlier iOS. Like I said, mine is still using iOS 10, and that forced the App Store to give me the older version of Nighthawk. I don't know if iOS 11 is old enough to force Netgear to give you the older version of Nighthawk, but it may. Unfortunately iOS 12 will use the new defective Nighthawk app.
- DaltonMacMay 06, 2020Aspirant
We should not have to try work arounds. They just need to fix the problem!
